So, if the pumps jumps, do I pin the pump to keep it from jumping, or pin it and take it out so it doesn't break the pin off inside the pump? Worse case scenario, I could get a couple nuts and tighten them against each other on the pump shaft and turn the pump that way.
Jordan
Just clean the shaft real good, I use brakeKlean then hit the shaft with compressed air to dry it before i put the nut and washer on
Michael
