Thanks. Position 12 in fuse box is labeled I. O. D. which I have no clue what that stands for and yes I did check the fuses with digital v. o. m...
My mirrors ,,work in SOME postions ,,but not all.
Is the motor in the mirror housing or some place else?
THANKS
Mike IN Maine
Is the I. O. D. a fuse or a relay?
Isn't this were the battery cable connects to the fuse box?
Thanks B.G., I ended up pulling it out with a pair of plyers and that seemed to work. I looked it up in my manual and it said to give it a firm pull. I was concerned I would break it but alls good so far. Thanks again.To open the carrier you have to pull it out about 1/4" and it wont pull out any farther. Now you take a small screwdriver, or a knife, and pry the tabs on the right side of the carrier up, and the top will open up, and you can pull the fuse out.
