My current clutch is a 13. 25" Con FE. My problem is that it feels like it is not quite releasing all the way. I can get it into all gears while stopped, but I can't speed shift it, especially going into third gear. It takes like 1 second between shifts before you can feel it slide into gear, I don't want to have to jam it in there. This is my 3rd SBC in 5 years and one thing I've noticed with all of them is the harder shifting and also I can feel the truck move in low range when shifting into 1st or reverse. Is this normal for these types of clutches? I've measured the slave travel distance and it is in spec. I've put in a new hydraulic system and it didn't help. I also made a 1/8" longer slave rod and this had minimal effects. Removing my floor mat has yielded the best results, but it isn't great. I find that to speed the shifts up, I have to increase the rpm to say 1200 or so and it slides in much easier. So, do I have synchro problems, a bent input shaft, or is this just the nature of the beast? FYI, my current clutch has the ball bearing pilot bearing and has under 5000 miles on it.
TIA,
Dan
TIA,
Dan
