Question for those of you with spray on liners
Back from vacation with praises and a few questions
Farm Bureau Rebate
Just wondering if any of you who have the spray on bed liners ever load heavy pallets of stuff. I'm wondering if the material would have a tendancy to scrape off if they slide a heavy pallet up toward the front of the bed with a fork lift. I'm just not familiar with the durability of these liners. Thanks.
Hey Benson, Hows it going? Did you get your truck yet?, About the Liners. Go over to the Linex guy on Wible and White Ln By the Rainbow Carwash and Discount tire. He's real good at applying his product. I still might have my Rockers done by him even if it has to be done in Black.
1998. 5,2500,ISB,Auto,CC,4x4,White Sport,Isspro Boost & Pyro,275hp Injectors,VA,BD Pressure Lock,16x8 Eagles,295 BFG's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
26ft Weekend Warrior.
1973 R/S Z28 Camaro.
1989 Jeep Cherokee.
427ci 585hp L88 Crate Motor, Still in the Crate!.
LINE-X is a "harder" material when it is cured, than some of the others, that seem more rubbery. I think the ones that are rubbery are that way for non-skid purposes, or something. LINE-X won't peel up under the use you describe.
D
I have had a number of 2500# pallets loaded into my truck with a Line-x liner and have had no problems.
2000 2500 SLT QC Intense Blue 4X4 6spd, Line-x liner ,Bull Rings
My friend put a spray in bed liner in his 2001. So far he is disapointed with it because he is putting dents in the bed especially in the corners of the wheel wells and on the rails. Aparently the old style plastic bed liner insers help prevent dents in the sheet metal. The spray in stuff looks nice and prevents scratches but it will not keep you from beatin' the crap out of it.
I think how well Linex performs depends on the abilities of the technician that applies the stuff. Evan Beck had his done recently and it looks top-notch and appears the material was liberally applied. But the other day I saw a Dodge Ram from the local LineX shop and the material appeared to be VERY thin! So definitely check out the shop you plan to have do it ahead of time.
Vaughn
I have the Gatorback spray in liner. It is too soft for heavy use, but keeps things from sliding around pretty good.
1999 2500 24 valve Auto 4x4,loaded SLT,Quad Cab Shortbed,lim-slip 3. 54, Rancho 9000's.
I had a Rhino in my V-10. When I slid furniture or lumber or anything heavy on the bed, it cut into it. Never went all the way through, but scratched it up pretty deep. Went back to a drop-in in this truck. The ultimate would be a spray-in with a drop-in over it.
This is my second truck with a spray in liner and wouldn't have one without it. The Line-X is a harder compound so you can still slid the pallets in. I have not been able to scratch or tear the surface. A spray in liner is not designed to prevent dents and dings, but it does keep it from rusting. The plastic liners will wear the paint off even if you never have a load on it. Once the moisture gets trap under it. Surface rust will appear sooner than later. If the Line-X is applied by someone who knows what they are doing they look great. I am extremely happy with mine and would recomend it to anyone who uses thier truck like a truck.
They also cut down on some of the road noise through the rear of the cab.
2001 Flame Red Sport, Auto, 4. 10, 4x4, LOADED!, DC Sport Brush Gaurd, DC Painted Running Boards, DC Splach Gaurds, Line-x over the rails
1998 Durango SLT+
2000 FL60, 16 ft. Flatbed, Cat Powered
Rock Solid and Looks Great!!! www.armacoatings.com Sprayed in HOT
01 Ram 2500 QC LWB ETC
Dark Garnet/Driftwood
All options except heated leather seats added Smittybilt SS Side Bars and EGR Bug Guard,ARMA Coating Bedliner
And I Love it!
Had a Line-X installed just after I bought my truck. I worried that it would dent the first time I put something heavy in, but it still doesn't have a scratch. It is TOUGH sutff. I am very satisfied.
2000 2500 Quad Cab, SLT, 4x4 Auto, 3. 54 LSD, Forest green two tone paint, all options except leather and CD player, Fisher 8 foot minute mount plow, Dodge Sill Guards, Dodge mud flaps, Dodge bug deflector, fog lights (installed myself), Line-X bedliner, Back-Rack ladder rack, Viper remote starter/alarm.
Spray in liners are better than the alternatives- had the rubber mat #ad
seen what the hard plastic does to the paint #ad
have the rhino and have gouged it a bit and put a dent or two in the bed- but unless you have an armor plated bed or never carry a load you 're gonna dent your bed- just make shure you see the quality of work that the applying shop does and talk to a few that had it applied there---- #ad
good luck
99 slt Quad Cab 2x4, rhino liner,ultra boards ,pace edwards rolltop bed cover, rbw lit'le rocker #ad
[This message has been edited by dabubba (edited 08-10-2000). ]
Thanks for the word guys. I've tried about every combination except for this spray on stuff. I think I am headed that way. I was just concerned that sliding a heavy pallet forward might scrape the stuff off.
No truck yet Doug, I'm trying to find out the status. It's hard to get through.
benson , if it scrapes off , they will fix it , i put in a piece of plywood for use when i need to slide something in and out .
sean the drop in dents the bed also , the liner pops out and the dent is hidden underneath.
I have the Rhino liner and lately have been buying pallets of landscape blocks for my yard. These weigh about 2500 lbs and are slid in the last 2' by forklift, I'm on my 10th pallet and have only taken one pea size chunk out of the liner on the tailgate. If I remember right when I got the liner they said if I damaged it they would fix it free.
2001 black dually,4x4, 6 speed H. O. ,loaded up. Jacobs E brake, lighted running boards, toolbox, solor visor, mag hytec cover, rhino lined, diamond tread rail protectors, mud flaps with genos chrome plates, megs exhaust tip, SPA digital pillar mounted pyro, boost,fuel press & oil temp gauges, rerouted blowby bottle, torklift class 5 double tube extension hitch and frame mount camper anchors... Its not a hobby anymore, its an addiction!
Any of the major spray-in bed liner companies offer a lifetime warranty against damage hence, they will repair it free.
For the absolute best in bed protection... several TDR members have installed a plastic (under the rail) bed liner OVER the spray-in bed liner. Just a thought.
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Bosch 275s, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, ATS exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
Thats why I bought a $600 5x8 Utility trailer, I did'nt want to trash a $32k truck when $600 trailers are available. Plus the trailer will hold 3,500lbs of rock!. Who cares if the trailer gets dented,scratched,bent,burned,squashed,ripped or crushed, Its only $600--> Very close to the price's of some Spray liners!
Doug.
1998. 5,2500,ISB,Auto,CC,4x4,4. 10's,Suregrip,White Sport,Isspro Boost & Pyro,275hp Injectors,VA,BD Pressure Lock,16x8 Eagles,295 BFG's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
1989 Jeep Cherokee.
[This message has been edited by DieselRam (edited 08-14-2000). ]
