Attention: TDR Forum Junkies Originally posted by Boldt's Wagon
I put the all steel cord 235/85R16 Michelin XPS Ribs on my trailer. No "trailer" rated tires were available at the time I bought the tires.
Now there is a new "trailer" rated tire available available in 16 inch (ST235/80R16, load range E, 3520 lb rating) , see:
http://www.titanstore.com/store/RADIAL_STII.html
Originally posted by bdaniel
I just put Michelin 245/75-R16 load range E light truck tires on my fifth wheel and couldn't be happier. I kept hearing the sidewall argument but with the Michelins loaded to about 65% of their capacity and 80 pounds of air pressure I can twist them all I want in a turn and the sidewalls look fine.
Bobby
Originally posted by rweis
My 3500 has LT 235/85/R16 load range D.
I am looking at a 5 er that has LT 235/85/16 load range G not radial.
Ideas on changing the 3500 to radial load range G?
I hear the discussion on the flexing of the 5 er side walls and the need to maintain stiffness there. Maybe just bring the truck to load range G and radial and use the truck spare for a short distance for the 5 er if needed. Would not have to carry 2 spares that way.
Bob Weis
Goodyesr makes a G rated tirer Called a G614 Steel ply side walls. They run with 110 psiOriginally posted by Prairie Dog
This has been a debate for years now. Radials stop better but bias ply's handle the sideways flexing encountered by tandem axles better. Ever watch your tires when making a tight turn in a parking lot? It isn't pretty. The extreme flexing can pull loose the belts inside radials but I've noticed that just about all new travel trailers come with radials now.
If you go to radials make sure their load r
ange "E"s.
The rating for G rated tires is amost 4000lbs. Mixing E and D rated tires makes for a strange tow reg GM put D's on the Fr & E's on the rear of our 3/4 tonOriginally posted by mberry
A couple of questions.
1. Are you sure the trailer tires are LT and not ST?
2. What is the rating of G tires?
If it were me I would not change the truck to G tires unless all it was used for was towing the 5er.
If I used it for daily driving as well, I would probably leave the rears alone and change the fronts to load range "E". Then change the rears to "E" when the D's wear out. If money were no object I would change them all at the same time on the truck.
