Such a simple job yet I still managed to #@&%*@ it up.
Changed the fluids in both axles last night (first time). I was a little surprised to find a plastic gasket on the rear diff as I was expecting RTV. I wasn't 100% certain that the gasket was reusable so I put a thin layer of RTV on both sides and slapped her back together. Checked the service manual for torque values before I started. 40 N-m or 30 ft-lbs. By the time I got the cover off, had a heart attack over the amount of metal in the oil, pondered the gasket issue, etc. I managed to get the torque numbers turned around in my feeble brain. The very first bolt I tried to torque down snapped off before it hit 40 ft-lbs. Of course it had to be the one at the very bottom. I figured what the heck, the Mag Hytek unit doesn't have a bolt there so why should I. Actually I didn't have much choice as this is my only ride. I was kind of hoping the RTV might help keep it from leaking. Drove about 35 miles today and so far not a drop.
Now I'm wondering:
1) Are the plastic gaskets reusable?
2) Did I make a big mistake by using RTV?
3) What are the odds of my getting by until the next change with one bolt broken off?
BTW - the front axle went just fine, no visible metal in the oil and very little on the drain plug.
Thanks for your comments/suggestions... ..... Dale
Now I'm wondering:
