Well here we go again. After replacing the rear main seal with sleeve from Cummings I still have an oil leak. I have taken it to a mechanic to let them have a try. When I installed the new seal with sleeve I used Permatex
High strength sleeve retainer with the Permatex surface prep. I bought the install tool from 4X4 Tech Inc. in Montana and went forward thinking that I did a good job.
I'm beginning to think that it has something to do with the seal retainer which means the Bell housing has to come off. Somehow this ties into the pan and I believe an oil leak can develop from the pan seal into the crank area.
Has anyone had experience with this problem and if so how did you fix it.
I need some ammunition to show the mechanic. Hes thinking thats not the problem. I'm not so sure.
Thanks
Mike
Thanks
Mike
