rear pinion seal
Front Wheel Bearing?
Lift size for front sway bar blocks
The rear pinion is leaking, having a new seal put on at dealer need to know the quanity of amsoil I need with the mag hytek cover. trying to find some amsoil in tampa is not easy?
Nearly 7 quarts! Any you may or may not need to additive from Dodge. I tried the additive from Amsoil in my wifes 2k but for some reason it didnt work. .
You should be able to call direct and have them set you up as a dealer...
Rick
