Replacement Steering Stabilizer
Lost speedo, abs lights, nav error??
Santa stopped by early!
I plan on upgrading my steering to the 08+ style and am wondering about which steering stabilizer to use, other than the newer style Dodge one. My tires and rims are stock as is my suspension height. I don't think I need a dual set up, nor do I want to spend that much money. What about Rancho? Shadrach
I would check to see what Kore or Carli Suspension offers. I know Carli uses Bilstein. If you like Bilstein and want to stay with the stock location, Geno's has Bilstein stabilizers for the 08-10 trucks.
Source Automotive sells the '08 upgrade w/zerks for a nominal increase. They supply a Rancho or Skyjacker I believe. Using one of the pressurized ones will yield a left drift especially with stock tires. Probably overkill for your situation.
Yhe Carli High mount stabilizer with Bilstein is a great choice and if you want to go dual you can but another in the stock location.
The Bilstein 5100 from Genos would be a great choice. If you want something a little better, the Bilstein 7100 from Carli that bolts in the place of the stock one is even better!
--Eric
Thanks guys. Both Carli and Kore are major overkill for me, although that hasn't stopped me in the past. :) They are both top quality products. Rancho and Bilstein are probably more in my budget. I need to fix the heater door problem first. Shadrach
Make sure you compare the OE to any "generic" aftermarket stabilizer you may consider... the Monroe I purchased a while back is significantly less stout than the OE, although; it seems to work just fine...
Thuren also has the Fox stabilizer. He also has a prototype with a King and a reservoir. It only uses 25 psi of nitrogen so it won't make the truck drift to the left. No word of release date however. I'd rank them as follows: Fox from KORE (more $) and Thuren = Carli/Bilstien. Either is higher performance than the Geno's Bilstien which is better than stock. I don't think the Geno's unit is pressurized so no steering drift.
i went with source auto and their stabilizer. it slows movement. the cylinder does not expand or retract on it own, its neutral. i really like the change. even my acra wife lover noticed the difference. much tighter and responsive.
Does anybody have Don's steering with a stabilizer? I'm currently trying to research doing the install. I used to have the Superlift dual setup when i had stock steering, it was so-so. I used the OEM replacement on my 99' and it was OK. I like the Bilstein line and am not worried about their quality. Any thoughts?
I went with the Carli stabilizer when I upgraded the steering from Source.
Not the high-mount either, just the regular Carli with the Bilstein shock.
Great link BDaugherty! I don't have the heater/blend door etc. problem YET, but this will be a big help in the future. Thanks!
I have two of Don's SS, one for each truck. It's your basic Fox unit nothing fancy or different. His price is just a lot better than KORE. On the 01, the clamp to the tie rod had a large OD (different from the 3rd Gen clamp) and it would contact the diff. cover. I have to do some detailed adjusting and grinding to get in to fit. The only other issue I had was my fault. BE SURE to point the Schedar valve up. I can get knocked off.
The Heater Treater stuff is top notch. I will solve the recirc door problem. I just did this in the 06.
