Engine/Transmission (1998.5 - 2002) Resonator
Engine/Transmission (1994 - 1998) Delivery Valve Washer?
Hey guys, just a quick question, just wondering if the resonator on my early 2001 cummins 2500 is a cat type, or is it for muffling the exhaust? It is only about 12 inches long if that, and would it be safe to remove?
Thanks for your time
It is not a CAT device but, if you have straight-piped your stock system you may not wish to remove it as you may experience drone a certain speeds. My stock system prior to the 4 inch was sweet with the resonator left in place after doing the Geno's straight pipe conversion.
Good Luck
William
I changed to a 4" system and removed the resonator but had to put a 4" resonator back on because of the drone was driving me nuts at 2000 rpm. And I'm hard of hearing.
Gary
