Matt400 said:I don't understand that. .
Higher Cetane reduces the chance of ping, advancing the injection timing increases the chance for ping. Any idea why they would make that statement?
Thats true and I got caught up in that having crossed over from the gasser world, so what you quoted- I was totally wrong.Elite1 said:From what I have read, Cetane does the opposite of octane (in a gas engine).
Graphite 6 said:Hi Guys, I guess my question is like a couple others, installed mine and see nothing in any form of improvment. So I wonder if it's a bad sensor or I don't know how to follow directions. The "pushing up" procedure after the hex screw is snugged, it only moves up and down about a quarter inch? So push it all the way up and tighten? Thanks for any clarification
FJfonda said:As promised in an earlier post, here is my update after towing the boat for a few tankfulls. I normally run Stanadyne PF and ran it on the 1st tank but not the second. The trailer/boat combo is 12,000 lbs and the route I towed on is one I have used often in the past.
- At light throttle the response is better and it "feels" like it is easier to gently get the rig moving.
- Full throttle response feels about the same both at low speeds and at interstate (65-70mph) speeds.
- Exhaust temp on the long climbs were slightly less (under 50 deg difference) and still stayed over 1300 deg (pre turbo) on long 2800 rpm 28 lb boost climbs.
- MPG's were within the norm for the trip coming in at 0. 5 mpg over average. I'd have to make the trip a few more times to verify the results. I normally see 8 mpg on this trip and saw 8. 8 mpg the 1st tank and 8. 3 the second.
Overall not the change I was hoping for but still well worth the $$ in the way the truck drives when not towing. BTW - fishing was excellent!!
Graphite 6 said:OHale, Thanks, I think I installed it correctly,however,I get no results whatsoever,and consequently can't tell if the sensor is bad or any other problem, which is ultimately what I'm trying to determine. I may be a little slow in responding, I only have this computer at work. Thanks again.
Motofreak said:Anyone running it with Juice/Attitude?
Where did you mount your A2?Bcutts said:Been playing with the juice and A2!
Matt400 said:Where did you mount your A2?
