I've searched the other threads for info on replacing the rusting trans cooler lines. All acknowlege that replacement lines are very expensive, and a solution appears to be you replace the steel with rubber. Anyone done that? How does one support the rubber lines? Has anyone cut out the rusted section and used compression fittings and hose to replace the bad piece? Its a 98. 5, 4 wheel 30. K miles, and i've already replaced the P. S pump body and fuel lines due to rust. thanks
