Sounds like an electronic issue. Maybe with the new VP you need to "reset" the APPS. I forget the procedure exactly but as I recall you disconnect the batteries a few hours, then reconnect. Cycle key to ON but don't start it, and smoothly press throttle pedal to floor and smoothly release it fully, and repeat two more times. Then shut off key. This essentially reprograms it. If I don't remember right how to do it hopefully someone else will chime in.
Vaughn
