My recommendation for shocks are Rancho 9000`s. They are the best I have ever used. In cab contol not neccessary. Very easy to adjust manually.
As for the steering stabilizer, I`m not sure what years your trucks are. Mine came with 1 from the factory. Its mounted to the frame and to the drag link. I`ll call this the "upper". I think in 97 Dodge added another stabilizer mounted to the axle tube and the tie rod. I`ll call this the "lower. "
Shortly after I bought my truck I added the lower stabilizer. This helps more than the upper one in my opinion. I used a Trail Master part# 7110. This has the brackets to mount the stablizer to the axle & Tie rod.
I had a Sky Jacker dual stabilizer kit that mounted in the Upper factory brackets. I did not like it at all. No difference.
Your best bet is an both an upper stabilizer and a lower stabilizer
Trail Master and Rancho are both top quality companies that sell stabilizer shocks. Replace the OE ones with a good aftermarket shock.
Rancho`s tech line phone # is 1-800-574-6257 You can get part#`s here ect.
Hope this helps
1994 Dodge Ram SLT Cummins 5 speed 4x4,3. 54 gears, Scotty Air System,PIAA Platnum Super Whites,Optima red top batteries, manual trans filter,Turbo&Exhaust blanket,Magnaguard rear diff cover,Edelbrock IAS shocks,muffler removed,Borgeson steering shaft,Trailmaster steering stabilizers,Rancho upper & lower links,Polyurethane sway bar bushings,Skyjacker 2" leveling springs(front),Fabritech Stage II Traction Bars,Denman Coyote A/P LT305/85R16(36" Tall) tires on Stock Dodge Chrome 16x6. 5 wheels,Bushwacker Street Flares,Back-off saftey brake light,Bugflector II bug shield, Royal Purple ,Amsoil& Red line lubes throughout.
1970 Plymouth Cuda (under construction)
1968 Hurst HEMI® Dart , Nah its just a screen name ;-)
[This message has been edited by 1968 Hurst HEMI Dart (edited 12-02-1999). ]
