Still not working like it should . Replaced the striped gears , put all the parts back on the frame , Replaced the slide control box ,checked the switch . Now the fuse blows as soon as I try to put it in the panel . I don't know how to trace for the short . The wires are all inside the frame and covered up with the sheet metal or in side the walls. I do not have a way to check the amps of the electric motor as the meter is rated to ten amps . I am thinking of putting the leads between the neg side of the battery to use battery direct and see how much it draws just to get the slide moving and if the amps go to more than eight ill let off . Any ideas welcome . Got the gear set for about eighty dollars and the control box for one hundred fifty five dollars . And I don't know if the box works or not . As I can only get the slide to move manually or direct from the battery by switching the red and black wires to change Pos to net , net to pos, seems to work fine . I don't know how the short came to be Or how to find it. Ron Bissett in Metro Louisville KY
: This in on a 95 Newmar American Star 26 ft single Slide RK MOD
