Engine/Transmission (1994 - 1998) sluggish on p-pumped 24 valve
I just p-pumped my 24 valve and now its really sluggish and it won't build boost past 12 psi, I used to make 40-50 psi. The fuel plate is all the way forward and the afc is all the way forward. I feels like it has no power at all times. PLEASE HELP, I need this truck for the farm.
The FASS might not be giving you enough pressure. P-pumps need more than the 24 valve pumps.
This ^^^^^^.
If the FASS was used on the 24V you'll need a different spring for the bypass valve in the base. The 24V is set up for 8-10psi. The 12V needs 17 - 22 psi at idle and 25 - 35 psi at 2500 rpm (no load).
Call FASS or a FASS dealer.
Thanks guys, I did get the updated version for the conversion from FASS I have about 40 psi of fuel pressure, I messed with the afc and it took about 50 psi of air to move the arm, I cleaned it up and adjusted the star wheel a little bit so far it appears to be better I will actually road test it tomorrow.
