Smarty CR software updates
diablosport puck OR Quad XZT ? ? ?
Turning Higher RPM
Thanks guys for your help!
I'll check them SW's out... . tomorrow.
Today my brain has a work overload...
By the time you get back onto the board, I'll have an answer...
For the 07's. The trip data is worked out. We're CLOSE to ready / ready for the first beta tests... . :)
Marco
Marco go get some rest! As for the 07 5. 9's will they be backwards compatable like the 03-06's as well? Same programmer for 03-07 trucks?
From what I understand it's may be the same programmer but, it can't be used on older models. The 07's programming is different from 03-06 so the software loaded on the programmer will be different.
the 07 smarty will use the same electronics as the 03/06 smarty and yes they will be loaded with grouped softwares.
more to follow
Marco, Did you find anything wrong with the new software update? Keep up the excellant customer service! Smarty is one of a kind
I loaded the updated software this weekend. I also noticed that the cruise EGT are now 25-50* hotter. The "moderate" program now feels like the older "mild" program - harder to spin the tires off-idle now!
Fellow BOMBers,
I've checked the softwares. No human factor involved... :( no errors.
Looks like ol' Marco is better than what I had thought. :-laf
I've also tried both the "new" and "old" softwares in my truck ( one more time. . ). Makes no noticeable difference in my truck . EGT's and power remain the same with both. It's amazing how these CR trucks react different one from the other to the same mod!
It looks like the new "anti rattle" timing is great for the guys with aftermarket injectors but not so good for the stock sticks. Hmmm, amazing.....
I can always re-do the softwares and have both timing's availabel for download. ( Is that a good idea??? )
Now before I do that, please help me understand exactly what's going on.
The lack of power and higher EGT's you notice is under "light" throttle only,
or????
Thanks!
Marco
This would be great! I have the aftermarket injectors, but since buying the adjustable timing TST a few weeks ago the Smarty before the "anti-rattle" changes works well.
Now before I do that, please help me understand exactly what's going on. The lack of power and higher EGT's you notice is under "light" throttle only,
or????
lack of power feeling is just off-idle for me. The higher EGT is under light throttle, lvel ground cruising on the highway.
The beta "anti rattle" program that Bob sent me felt stronger off-idle than this current "anti-rattle" program.
The original Smarty for the CR when first released actually felt the strongest off-idle - even more than the current moderate programs. Of course, the original Smarty CR program also had a very touchy throttle that a few folks didn't like.
Hope this helps!
JStieger said:
<<SNIP>> ... I have the aftermarket injectors...
AND ->>> The original Smarty for the CR when first released actually felt the strongest off-idle - even more than the current moderate programs. Of course, the original Smarty CR program also had a very touchy throttle that a few folks didn't like.
A buddy of mine's EXACT comments about the Smarty and his aftermarket (I believe DDP) injectors... He is going to try the newest software this weekend.
BUT - many times has he expressed the interest to get back the very 1st original software from the Smarty (he wants SMOKEY and TOUCHY THROTTLE)... :p
Just download the Moderate version. It's the exact same thing. Just no timing rattle.
Marco said:
Fellow BOMBers,
or????
Thanks!
Marco
Marco,
what do you mean by the new software is not so good for stock sticks?
