here ya go and if this don't help just send me your smarty and i will update it for you.
To be able to update your smarty ecm tuner. Please follow these guidelines.
Start by right clicking on your desktop to create a new folder. Rename the new folder smarty.
You will need to download the driver to the smarty folder. Save the driver to the smarty folder
http://www.madselectronics.com/downloadfiles/CDM_2.00.00.zip
You will need the smarty usb. exe This program allows you to update the smarty. Save this to the smart folder LINKS TO EXECUTABLE FILES NOT ALLOWED
The driver and the software programs need to be extracted into the smarty folder using THIS extraction tool. LINKS TO EXECUTABLE FILES NOT ALLOWED?download
Here are the directions for installing the driver
http://www.madselectronics.com/downloadfiles/USBDriverinstallation.pdf
Once you have the driver installed you can use the smarty usb. exe program to update the smarty software. Click on the smarty icon. Press run. You will now see a seen button. Before you hit the send button you need to load a program into the smarty usb. exe. Click on file. Open , look in the smarty folder to find the smte file to load into your smarty.
Load the file and press run. It will take about 40 minutes to update your smarty.
Bob
Here is a link to AlpineRams screenshots
How To Update A Smarty - Dodge Diesel - Diesel Truck Resource Forums
