Smarty Revo and Towing??
Bad injectors?
FASS pump question?
I'm going to download the revo and want to know what would be the best settings for TQ Managment,Timing, and Rail Pressure. I tow about 10-15k. I'm not looking for a lot of extra power, just safe and ECONOMCAL power. I currently run on the stock TQ. managment SW#1. It does fine but lots of smoke and timing rattle. Thanks, and sorry for another smarty question. :rolleyes:
It's available. I have been running it.
It's smoky on most levels. I just bought a TST and I'm going to try towing with it and see if my trailer stays a bit cleaner.
I tow daily and I set my Smarty to stock rail pressure, stock torque management, timing at 4 and original settings of level 1. Minimal smoke that way, and plenty of power for reasonable towing. I tried the other torque management settings and got noticeably more smoke. And you probably don't need a more aggressive throttle response towing anyway. With these settings I no longer blacken the right side of the trailers I tow...
Mario, what is your MPGs and EGTs with those settings? With my setup, I get between 10. 8 and 11. 2 mpg when towing and the truck runs great. Max EGT is 1200F.
I have been comtemplating running the Smarty on those settings (to improve MPG and maybe EGT), but don't want to push my transmission over the edge (I have injectors... )
For those with smoke problems, when I first got my injectors, I noticed a alot of haze when towing hard (with an aFe PG-5 filter and ram air holes in the stock box) which didn't happen when it was stock. The CFM+ intake manifold and the PSM cold air kit really have helped. I can't get it to smoke at all even when towing very, very hard.
I ran these exact settings a couple of days ago but noticed much more clatter with the timing on #4 and the #1 30 hp setting. The truck seemed to run very well, I was just unsure of how much the timing was advanced with those two setting combined. Anyone know what the advance level is? Bob?
I am running setting 1 now with stock torque management.
