Just wondering...
if you are running a pusher pump and your factory lift pump eats it, you won't see the drop in psi right? So it could be dead and you wouldn't know? Also, if you knew it was dead for whatever reason and you took it to the stealer, they prob. wouldn't replace it b/c their pressure test would should good pressure right? Finally, would they void out your warranty b/c you had a pusher pump?
