Something's sweating above the fuel filter...
chriscumminsdiesel asks:about tailgates....
A few questions????
"Mad Max"
Alright, so we're trying to figure out why the fuel filter in TJ's rig seems to be sweating fuel - case is wet and the drain at the bottom of filter is always wet. It was real bad (dripping) until tonight when we changed out the filter and drain valve with new ones, but it's still sweating, apparantly from above the filter, maybe from the fuel heater??
Is the fuel heater sealed with an o-ring and is the heater easy to remove, does it screw on, or has anyone been here and done this? All lines into the heater look dry and everything above the heater looks dry, but from the heater mating surface down it looks wet, and it just keep going onto the filter.
Kind of a pain and the smell gets old after a while - ideas?
- Sam
Hi Sam,
I believe that there is an o-ring on the fuel heater/filter mount joint that could be causing your sweating issue.
I'll look at the manual ASAP and let you know if there is anything else that could be contributing to your problem.
Sometimes when a filter is changed the o-ring gets pinched and/or the heater "block" can come loose... it won't take much to cause your situation. If you want, take a look at the assembly by removing it and checking what seal(s) if any, are between the heater block and it's mounting stud.
pb.....
Sam,
It is an easy fix. When you have the fuel filter off, unscrew the nipple that the fuel filter screw onto from the mount. That will allow your fuel heater to come off. There is a rectangular o-ring on top of that. That could be the problem.
Another potential problem is that during a filter change, the ring on top of the filter may not have come off one time. You intall a second o-ring and now it never fully seals.
Just another possibility.
Stay warm!
Carl
Sam dude,
You will be able to obtain said part no. for said o ring from the Feb/Mar/April 2003 issue of out beloved magazine. Look in the first gen pages.
-S
You did use a Fleetguard fuel filter which came with the square cut gasket or o-ring for the threaded top part of the filter and the o-ring for the water in fuel sensor right? If ya BTDT many times and of course Bill I did install both o-rings, then ya got me bro.
HTML:
sweating
HTML:
A friend once advised me...
"Don't sweat the petty stuff and don't pet the sweaty stuff ":-laf
good deal - I like simple fixes, thanks fellas. We'll work it here soon.
PB - y'all should have some tubular powdercoated 'eye candy' up at yer shop today I hope. Your brother still have his installed?
We did TJ's rig yesterday - made him feel better ;)
- Sam (tubular powdercoated 'eye candy' maker... )
Ooooooooo mannnnnn..... ECJ, you just ain't right dude... :D:D... . I think it's time for your confessional..... you EC guys are all half a sandwich short of a picnic. . ;)
Sam... . Yup,,, totally tubular... brought it up to the mystery puzzle house today bud...
Alas... my brother is now running twins... the rat... :D
pb...
....twins......
ahhhhhh yesss, twins are good..... only a matter of time amigo! Probably early summer. Um, make mine the towing variety, purty please. :-laf
- S
