Spare Tire mount
Help! Installed PS Boost Mod. - can't get over 20 PSI
Anyone looking for a solid rear window glass?
Greetings,
I am looking for a mounting system for aftermarket 35-37" tires. Obviously it won't fit underneath. I know that I can just leave it in the bed or buy a horizontal tire mount but there goes most of my bed. The diagonal mounts usually only work with a 35" or less tire and I still lose my bed.
Does someone make a swing out bumper mount? Is there a replacement rear bumper that has a tire mount?:confused:
Is there a rack for the top of the cab that can support the weight of a large tire?:confused:
Your thoughts are appreciated.
Thanks
Good Luck in your search. Be real careful trying to carry spares overhead. I ruined the top on a good E350 ford van doing that.
The welds between the top and the windshield frame broke and
despite 2 repair attempts it always leaked when it rained after that. I imagine the weight we were carrying, the 4 extra leaves in the rear springs, 10pr tires inflated to max recommended, and ?
all helped to contribute to the problem.
On fiberglass shell?
Has anyone tried to mount a spare tire on top of a cab-high fiberglass shell? If so did you use a Con-Fer rack, Yakima or some other brand?
Thanks
Berserker:
Check out J C Whitney catalog (or online) for a front mount hitch and accessories for carring the spare on the hitch.
Take a look in issue 24 of TDR. Andy Perreault has a rear bumper mount spare on his 96. The bumper assembly is pretty slick looking made by Rickard Engineering.
Front Spare Mount
DO NOT use a front bumper spare mount on your CTD.
The EGT's will go thru the roof from blocking airflow thru the intercooler, and will burn your diesel up. :eek:
Neither Cummins or D/C will warranty ANY engine work if you have a front bumper spare mounted.
Can't use front mount
Sorry guys,
I can't use a front mount anyway. Take a look at my sig or puctures on "Reader's Rigs". I have a Warn winch and mounting system. :cool:
I'll have to dig my old TDR's out of storage (just moved). That might be the best way to go. Does anyone have any on-line pics of rear bumper mount tires?
Thanks
Awesome
Now that's one fine looking bumper. :)
Now, does anybody know how to get hold of Rickard Engineering? Are we sure that's who make it?
My understanding a year ago was that Rickard Engineering is/was a one-man operation, and Mr. Rickard was ill and no longer making the bumpers.
The old address was:
Rickard Eng. & Mfg.
350 E. Orangethorpe, Unit 14
Placentia, CA 92670
714/524-5632
