Question ?? When removing the starter from the diesel,what tools are needed other than a 10MM 12 point socket to get the mounting bolts loose ??
When doing my return & supply lines I thought I'd have to remove the starter. As it turned out I didn't have to remove it ,although I think it would have helped.
When I tried to remove the starter I got to the bottom bolt on the right and could not get the socket to turn,even with a 3/8" breaker bar. There was interference with the starter not allowing the socket to turn. Remember this was a 3/8" drive. A 1/2 " drive would never fit in my opinon.
It looks to me like a 10MM 12 point combination wrench is needed to remove this bolt. Any suggestions ??
Just trying to do some planning for future projects !!!
