Engine/Transmission (1998.5 - 2002) Steep Hill Fix for Oil Coming out of Engine???
Engine/Transmission (1994 - 1998) 180 pump vs 215 pump
Engine/Transmission (1998.5 - 2002) Air in lines!!
You know that they say
3. 2 hours - I can't believe this procedure can be done in that time - all the stuff they're removing--THE VP 44 Also --- and to think this was reimbursable under the warranty--that makes me mad - IT SHOULD HAVE BEEN MADE THAT WAY FROM THE BEGINNING :eek: !!!!!! Let's be realistic - people assume when you purchase a 4x4 that you can RUN IT ON STEEP HILLS! On mayne not - I forgot that these things were designed by FLATLANDERS :eek:
That breather kit lists for $359—a fairly spendy fix, hired out or not. I recall a few on here having it done under the TSB.
