Wholly PITA...
I installed the Maxx Links and the Borgeson shaft... my center bolt holding the two halves of the OE shaft together sheared off. That created a bunch of heartache... had to take the shaft out wholesale, then cut it to get the firewall boot off.
The Borgeson did tighten the steering; but I checked, double checked, triple checked, and quadruple checked my OE shaft... there was not a single sign of play in it. What I feel is happening isn't the shaft itself causing the play, but looseness of the splined connections. I would guess that if you would take the OE shaft, and drill the couplers for set screws; they would tighten up as well.
Another thing of interest is that the instructions tell you to file a flat off the box splines (for the set screw). My box had a groove in the shaft that the set screw seated into, so I didn't file the flat.
I found my end links weren't really that bad at 245k, but I replaced them anyway. I was impressed, the end links on both my 94 and 99 rams failed within 75k miles.
