May be Im to picky about things, but here it is. #1. IMO The 2 main bolts used in the Windecker kit are not sized properly. First let me say there is NO WAY you should use the 5/8x2 1/2 upright bolt especialy if you put a washer in between the bushing and bracket. I personaly ground half the metal around the frame bushing off and ground a relief on the bracket to make room for what I didnt take off the frame. The bolt shank SHOULD BE nearly up to the nut on top! Go get a 5/8x3" and just cut the extra 1/2" off the end. Even with the EXTRA 1/2" of shank on the 3" you still have treads to spare! Next the tapered bushing I got had 4 an a half thousandths slop on the bolt shank which is one thing but couple that to the fact that the "short" tapered bushing will go up into the hole well beyond the face of the bottom of the frame busing! And this is supposed to "tighten up"? give me a break. First I was going to make a new tapered bushing but instead I took one of the grade 8, 1/8th thick washers and drilled it out to precisely slide over the bolt shank diameter, then i jiged it in the lathe and turned a taper on it's OD to act as a extension of the original taper bushing. This new taper washer comlpetely pressed the taper bushing up into the hole the FULL 1/8th" of its thickness ! Tapered bushings are completely USELESS unless they have a "pressed in flush with the face of the frame fit". This press fitting of the taper bushing would actualy eliminate 1 or may be 2 of the 4 thousandths slop of the shank in the hole. Next, Do your self a favor and relpace the "short shanked" 9/16 x 3 track bar bolt with a 4" one and run a Die down the treads and thread the shank untill you have a FULL 2 1/8" of shank. Years down the road you will NOT get a egg shaped hole starting in ONE of the bracket ears that holds the track bar because the original bolt shank did not ride in BOTH ears! I know, the OEM one on the other end is also short shanked. Its funny how small things like stearing wander leads to new truck purchases! The eye of my bracket was off by at least 1/4" to the frame cross member hole. so what I did once the bracket fit flush to the frame bushing is put a angular hack saw cut about 1/3rd across the width of the bracket from the were the major bend is near the shoulder of the oblong eye hole. Then put a similar angled hack saw cut about half way thru on the other side ALMOST joining with the opposite cut. Leaving about 3/8ths of metal inbetween the 2 cuts. Now I vised one end of the bracket and beat the other half closing up one cut while opening up the other cut untill the eylet matched up perfectly with the droped down bolt in the frame. Now stick weld the hack saw cuts back up. Mind you, I did this AFTER i hot forged a tighter bend into the bracket so it would be "closer" to the bottom of the frame. Don't get me wrong here, I am happy SOMEONE sells these brackets. I got rid of at least half of the wander in the stearing with this mod So Im not done yet. Sorry for the long post but Im surprised no one elas happened to think this was worth mentioning.
