photowrite
https://www.turbodieselregister.com...pgrade-to-19-5-wheels-and-G-rated-tires/page3
The above thread (and others) here are interesting and helpful, but I want to ask specific questions about 19.5" tire wear, so I started this new thread. I put this in the 4th-generation section, but really this should be an almost universal question/topic for guys running these setups.
I'm very knowledgable about tires and wheels, and my personal preference has always been for narrower OEM wheels and relatively narrow tires that don't stick put beyond the fenders. I'm currently running Toyo AT II 285/75R18 tires on OE aluminum wheels. I love the size, but preliminary use/data leads me to believe that I'm not going to get long wear out of the treads, and I'm not surprised. With the Cummins torque and the rear axle load, possibly fast wear seems common.
Application:
-2014 2500, G56 6-speed.
-2000+ pound, slide-in popup, camper. Relatively light by camper standards but the truck is getting much armor soon, carries tools, etc., and will be at or above the 10k GVWR much of the time.
-sees more dirt and technical trail use than most 4WDs (of any flavor) for camping, exploring, hunting, etc.
-pull trailers too, smaller utility trailer on up to a 8,000 pound 30-foot ball-hitch travel tailer, and considering buying a 10-12k GVWR car trailer.
Also, I don't let my tires wear down too low before replacing them, as low tread make for less traction, particularly when it's sloppy (snow, slush, mud). One way to get more miles out of tires is to start with more tread depth, I prefer 18-20/32". As expensive as medium-duty 19.5" tires are, they are not that much more (depending on brand/tread) than LT tires if they wear is substantially more/longer.
Many years ago when running a couple Cummins and then a '96 F-350, I didn't have much interest in the 19.5s because the lack or a safety bead (airing down in the dirt) and the overall wheel/tire weight, but I also was not running a slide-in camper.
To make upgrading to Rickson 19.5" wheels and medium-duty 19.5" tires worthwhile, there has to be a substantial performance increase, which for me would be tire wear. Surely stability would be improved, but with a popup camper my stability is actually quite good, so no complaints there.
Qs
How many miles are you getting from 19.5-inch tires hauling heavy campers and/or pulling trailers?
What size? [265/70 should be 'right' for me.]
How many thirty-seconds of tread did you start with and how much remains after how many miles/type of use? [miles per 1/32"]
Your duty cycle, power mods, driving style?
How are you keeping the heavy tire/wheel assemblies balanced? [I have Centramatic balancers currently, thinking tire beads may be a good call?] Running smoothly down the highway is important to me.
Any serious trade-offs you don't care for after some saddle-time?
I'm willing to give them a try, though if I don't like the setup there is a limited market for these wheels and shipping is almost completely out.
Thanks,
James
Application:
Qs
Thanks,
James
