I'm really puzzled, for the last two months I've been chasing a fuel system losing prime. First I've traced and inspected from the fuel tank, to the lift pump, fuel filter, to the injection pump, to the injector's, return lines back to the fuel filter, also from the overflow valve back to the fuel tank. I replaced the lift pump, Overflow valve ,the ball check on top of the fuel filter returning from the injector's. I cannot smell or see any diesel leaks, that's why I thought I had an internal problem. I put new hose's on the supply and return lines from the fuel tank but so far nothing has help. if it set's and hour it get's a little cranking problem if it set's overnight it's very hard to crank unless I use the manual prime button on the lift pump. Which is as we know a hassle. Any thought's or suggestion's would be appreciated. Hoof
