Thanks in advance for any help. I am a pretty good mechanic but have not done an injector pump before, so I have a few questions.
My truck is a 2001 automatic, and I have purchased a new injector pump from Midwest Injection and also got the FASS DDRP pump to install at the same time.
I have read all the directions and got the necessary 19mm crow foot and stubby wrench to help out with the fuel lines. I have the rest of the tools I need for the job.
Considering the above, I have the following questions:
1. For the puller, I can get a couple different ones via rental at Oreily here, but I am concerned about the bolts going into the drive gear. I think they are M8, but I want to get good ones to prevent breakage. What size are these bolts(both thread and good length to use).
2. My kit came with no banjo washers. I went to the local cummins dealer here in Austin and got all of them I need. I assume re-using old banjo washers is a bad idea.
3. The directions describe bleeding the injectors after I install the new pump. Do I just leave the intake horn off and crack the lines at all the injectors, then crank the engine? I assume that with the lines loose, not enough pressure will build to actually fire the injector and cause the engine to start? Is this correct? How long should I crank the engine to bleed the injectors properly?
4. My pump came with a new woodruff key installed, which surprised me. Should I go ahead and use this one or take the one out of the old pump and install it in the new one? I was surprised by this. Also, the key is higher on the small side of the taper(nearer the threads) than the taller side, which I guess means it is installed with the top horizontal with the center-line of the pump shaft and not parallel to the taper of the shaft nose. Is this correct too?
Any other advice for those of you with experience with this job? I am afraid of somehow dropping the key into the gear case or messing up the key and having bad timing more than any other potential problem, but I only know what I have read in directions and in the posts here that I have searched since I got my dead pedal codes a few weeks ago on the way home from a trip. So far it is still running, but I want to get this fix done before it totally fails and leaves me stranded.
Thanks again for the advice and help.
Jon
Jon
