AKAMAC said:Nice picture... ... Cold dead body sitting outside, heart sitting inside... ... RD that looks slick. What VP are you using? Mike
justinp20012500 said:Looks pretty easy to make a stainless (or whatever you want) manifold to bolt on there.
Can you access the intake ports on # 6 with the intake whacked off?
What are you plans for securing another intake piece on there?
And how many cut off wheels exploded during the whacking session?
Justin
RacinDuallie said:Justin-
For your questions above have you been following the thread at all???
RDLeader-
Roman- seems to me that a gang of crickets has taken over for you.....
How is that Twin Intake Horn coming along??
Justin
I'll answer your questions in the order that you asked them o. k. ?
1) Define easy!?! ( most guys on this forum don't have the coconuts to try this type of mod)- go back in thread- it's right there- I- was told in a round about way that this would be a waste of time and money- We'll see on that!!:-laf
2) You have access to ALL ports (see pics) I'm drooling all over my diegrinder right now. And how were you accessing the ports with plenum on? you don't!!
3) My plans are to continue on with THE RAMIFOLD !!![]()
(My truck will be the test bed for it. )
4) No cut off wheel explosions here!!(Holy Smokes!! Is that how you work?)
:-laf !!
justinp20012500 said:I saw the pics. . Looks like I will cut mine off this weekend.
It would take about two or three days of making sparks in the garage to whip up something to cover the ports. From the looks of it you will have no problem making something WAY less restrictive then the stock cast plenum.
Replacing all the sensors should not be a problem. I have a inoperable MAP sensor that I can send you to get started on placing it. Let me know if you want it. I might be able to come up with a IAT sensor too.
Just have to make sure you leave a "hump" in the new manifold to compensate for where the VP needs clearance.
justinp20012500 said:The blocks crack right above the big freeze plugs at the back of the block on the passenger side. It is a really big problem in the blue bird busses.
The 53 block had only 2-3mm thick out block walls there. Cavitation could be to blame, but I blame it on a pour cast. The 56 & 55 block have a 6-7 mm wall there. I don't think there has been a single case of a 55 or a 56 block cracking.
Justin
COMP461 said:Ray Little at RAYMAC has a nice Titianum retainer , and spring package , it sets up in stock location has around 135# on the seat , and will cover . 550 lift for just under a $1,000
RacinDuallie said:Hey Justin-
I'm surprised @ you... . Did you not see post #115 in this thread ( pic with MY 53 code casting block) you didnt say a thing!! in fact NOBODY caught that one!!I took a grinder to mine, thin walls you say, poor casting,
big problem.
More likely- from improperly fed cylinders... ... ... ... ... ... ... ... ... .
Todd T said:Scheids has Ti retainers and springs that do the same for about $220
Ol' Raymac is deep staging in someone's pockets. LOL
