Darkbloodmon
the countershaft oil guide and any shims made it back in right
One shim on the main shaft no shims on the counter, counter oil guide was not removed. pics below of my clean up and prep.
Further how many miles on this NV5600 and how does it shift? IMO people change clutches and forget the trans syncro's and bearings also wear out. Esp. when the oil gets sheared down in viscosity in 30K miles or so.
Again you can have two problems, but, the noise could be just the clutch damper.
Notchyness comes with age
I highly recommend it. Why fight a worn out transmission?
I wonder if spinning the output shaft of the trans would make noise and help pin its source down. Engine Off of course.
Can this 8 or 16 spring disc be built or the design modified to improve it's noise dampening traits, only slightly and usually with one of the springs being exchanged for a very light spring rate and the internal window of the damper modified to permit this "modification" to the crude strong parent disc.
Can't hurt to ask.You're the customer I don't think asking for a torsion damper curve of the exact disc design that you bought is beyond a reasonable request for tech support.
With all due respect, it was not easy. I need a definitive answer and sure solution before re-installing this trans for a second time. I'll send out both discs to be tested if need be. I'm hesitant asking a friend to use a shop lift because I don't know what's wrong, and I can't have this sitting in a bay waiting for clutches to be tested, or for a new one to be shipped back. Time is money, and I'm running out of free favors.If it was easy to install the trans again using a stock disc and make no other changes you might get an answer as to is it the disc or the trans?
I assume the oil guide/slinger is a snug fit in the seal retainer. It also looks like there is very little clearance between it and the input shaft bearing. Is it possible it is not fully bottomed out/seated in the retainer and is making contact with the input shaft bearing?
Frequency or interval between power pulses decreases. They are blending into each other rather than pow pow pow now powpowpowpow
Is it a helpful clue? We already know something is grinding in the housing or front of the transmission.
Would increased rpm make a grinding noise quieter or louder?
