Originally posted by clem
Airstream & Avion used Mor/ryde in the 60's. Avion went to Tor/flex in 1989 trust me they cannot be adjusted I had them on my 1989 tri axle and on my 1998 Avion thats why I have Mor/ryde now. also Airstream now uses HENDERSON suspension when they stopped useing Mor/ryde: Before Avion went to Tor/flex they used what they called walking suspension. What it was a Dextor axle cut in half and held in the center of the trailer so they could lower the trailers,but in 1989 the bean counters got in there and it was cheaper to use Tor/flex,and as anyone who has towed with them knows Tor/flex has very little up and down travel. This is my 3rd Avion so thats why I know about Avion plus we belong to the Avion Club. Also on the trailers that had half axles they had adjustment holes to adjust the caster,camber,and toe they were not bent to adjust. adjusted 1or 2 in the driveway
Clem:
While you may be knowledgeable regarding Avion TTs, the information you have posted regarding Airstream trailer suspension is simply inaccurate and should be corrected here.
Airstreams were the first to use the torsion axle design and have used the same system from the early 1960s until the present. Until recently I owned a 1966 Airstream Safari 22'. Its suspension system is/was identical to other Airstreams I have owned including a 1993 and to even later models owned by friends. I have never seen or heard of an Airstream using Mor/ryde.
The only difference between the early torsion axle systems used by Airstream and the present ones is that now they are manufactured a few blocks from Airsteam by a company called Henschen, not "Henderson. " I think the torsion axle system was originally designed and patented by Airstream engineers and the systems were manufactured in-house by Airstream beginning in the early 1960s. The right to manufacture the suspension systems was sold to Henschen by Airstream or its parent corporation, in the early 1980s I think. The suspension systems manufactured by Henschen are the identical design using a forged steel arm within a steel tube cushioned by rubber rods that resist twisting. As of about five years ago, Henschen was located just several blocks from the Airstream factory in Jackson Center, OH. I have visited the plant and observed the axle systems being made during a visit to Jackson Center to tour the Airstream plant and have service work performed in the Airstream service center. It is an interesting and surprisingly simple design and process.
Airstream torsion suspension systems have, since the 1960s, been aligned by the bending process I described. Airsteam service shops and truck alignment shops have performed the alignments as long as Airstreams have been in service.
Many manufacturers around the country are now manufacturing and using a system based on the original Airstream torsion axle design. Even Southwest Wheel located in Lubbock, TX where I live manufactures knock-off systems in-house for use on flat bed "hot shot" gooseneck working trailers, utility trailers, and stock trailers.
If anyone wishes to challenge the accuracy of my comments please call the service manager at Airstream in Jackson Center, OH or one of the many Airstream service centers around the country. The one mentioned by Bill Stockard is one of the older ones and its owner and staff have many years of experience. Griffith RV Service in Oklahoma City is another. Tom Griffith has worked on Airstreams since 1964.
I will obtain the phone numbers for the Airstream factory and service department in Jackson Center and the number for Henschen and post them here if anyone would like to call.
Regarding Avion systems, I have only owned one Avion, a 1987. It uses a suspension system called "Adjust-A-Ride" in the 1987 Avion factory brochure. That system was built by Dexter axle using half axles suspended on a steel flange in the center and using an outboard leaf spring. While they are adjustable as you stated, the available range of adjustment is limited. My trailer had an axle that was bent sufficiently when I bought it from its original owner that one of the tires was wearing unevenly. I discussed the problem with Chuck Cayo, service manager at Cayo Repair Service in Watervliet, MI. As you may know, Cayo Repair is "the" Avion repair center. Bill and Chuck Cayo are descendents of the founders of Avion. Chuck advised me that he can still order replacement axles from Dexter but I considered them pretty pricey and decided to try to have mine aligned first. The local truck alignment shop I took it to first attempted to put the axle back into proper alignment using the factory adjustment. The limited range or adjustment would not allow proper alignment so they bent the axle as I described in an earlier post. It has worked great since the procedure was done.
I don't have a wide range of experience with Avions but I have never seen or heard of an Avion using torsion axles. Can you tell us the year and model of Avions using them?
My interest here is to accurately report the facts. I hope this information will help someone maintain their trailer.
Harvey
