Engine/Transmission (1998.5 - 2002) Torgue spec
Engine/Transmission (1994 - 1998) trans Coolers
I ran 1/2" line to the IP and the fitting with a flat washer that screws into the IP was leaking. So we tightened it a bit, still leaked. Then tightened it again and the fitting broke. It looked like a bad fitting cause it was real thin on the threaded portion that goes into the IP. Anyway, new fitting on the way but how tight does this connection need to be?
