Well now I am mad,Mine says only 6040 rear, 6000 front w/18's....??
Mine shows the same weight 6040 rear 6000 front with factory 275/70/18
Where is the RV park?This will make for some good conversation...... 2017 Ram 2500 go ahead I'm ready!
Firestone Air Bags
Big Wig rear sway bar
BILSTEIN shocks front and rear.
1996 Harley Road king in the back!
The White 3500 gasser is my brother in laws View attachment 135673 View attachment 135674 View attachment 135675 View attachment 135676 l
That park is in southern calif we spend winter thereby some of our kidsWhere is the RV park?
Firestone Air Bags
Maybe too much air in the bags?
You might be right, I try to keep the truck sitting at the stock Hight. I also let the air out of the bags when we stop for the night and have to manly fill them every day. I need an onboard compressor! This picture I had 50 lbs in the bags, and since I would be driving in the dark, I don't have any issue with the headlights hitting the ground. But at 40 pounds she's level.
Depending where we stop trying to get the rig somewhat level. I have a level mate pro on the rig so if I am lucky to have a enough space I can usually get is close to level but other times its easier to let some air out. Thanks for the coil spring tip I will do that next time and try it out.
When I bought this trailer I was going to get a 1 ton truck "and I still might" so I decided to drive out west and see how it felt and I would decide when I get there.
I take the southern route down 35 then across 40 west. I drive at 62 or 63 mph, I don't use 6th gear with towing and manually shift. transmission runs at 167deg I get 11 mgp pulling and 23 not pulling. the truck is amazing and paid for. We aren't full time campers we have 2 big trips a year then some Midwest stuff.
It doesn’t really hunt for gears, but it seems at 62 or 63 mph it’s down around 1500 RPMs just a little luggy. And fifth it stays right about 1800 to 1900. I feel the same way about the truck I think 2500s are severely underrated.
