Happened in 2H at about 50 mph. Both times. I can say this, that the loaner Ram also a new 2500 4x4 manual txfr case works fine. It also has smoother txfr case shifting action than mine.This is bothering me. If it jumped out of gear in 4 hi or 4 low, I would assume linkage adjustment. But, since 2hi is not on either end of the shifter travel....???
The shift lever has nothing to do with where the fork position is, it just moves the linkage/fork to the next detent. If 2hi was not engaging the detent, then the linkage would need to be so far out of adjustment that neutral, or 4 hi would also not be available.
So here's a question, is this truck worth keeping if I can verify the shift linkage is set correctly? If the linkage is correct then the question is what else is causing this? A defective engine transmission mount? I really dont want a 3rd on the road out of area failure.
