transfer drain plug leak
1998 Dodge Ram Cummins 5.9, lost vacuum behind fire wall.
loud noise on startup this morning
2Farr
I have a 1999 3500 4wd automatic with a NV241HD transfer case. I changed my fluid in the transfer case the other day and torque the drain plug to spec and have a oil weep. The plug is a allen type. Is there a better plug out there or is thread tape the fix.
My neighbor (the one with a 2500 drw) showed me a great fix. The cummins oil pan drain plug is the same size and thread pitch as the transfer case plugs. You can even use the drain plug gasket. I had an extra in the shop, so I used it and works great no leaks.
Or you could do what I did for quick reference as to how much fluid is in there...
not to get a bunch of bad write ups, that is what I have on my offroad buggy for checking the amount of fuel in my buggy mine uses some 1/8 clear fuel line with quick disconnects.
