Engine/Transmission (1998.5 - 2002) Transmission Woes
Engine/Transmission (1994 - 1998) what causes loss of idle speed?
2nd Gen Non-Engine/Transmission Rear sway bar link help
Hey all,
Serviced the auto transmission in my 2000. Adjusted bands, filter, fluid. Level is good. Now shifts like a bugger. On test drive, put in reverse and delay, then hard into reverse. While driving stopped at a stop sign. Went to accelerate and nothing, just reved the engine, delay, then started to move.
Did I screw up this service? I have ordered the transmission speed sensor from Genos...
I have now disconnected the batteries and will reset the APPS...
Any ideas?
Cheers.
Don
Yes, low fluid level!
Check it warm, running in neutral, on level ground.
Bring it to the top of the hash marks.
Yes definately... . and now that the B&M Drain Plug ordered from Genos is installed... . much easier fluid changes!
Cheers and thanks.
Don
