2nd Gen Non-Engine/Transmission Tried to flush brake system - broke off bleeder
2nd Gen Non-Engine/Transmission Front end rebiuld
Engine/Transmission (1998.5 - 2002) Drag Comp Problems
anyone have the part number to go w/the larger wheel cylinders for my rear drums. Since I snapped off the bleeded might as well upgrade. Are they for a Chevy 1 ton? If so what year for mine. Make and part number helpful too. Thanks
I have the box at home for the GMC one ton wheel cylinders. If no one answers your question, later on I'll post the information for you. I got them from the Auto Zone. And they're life timers.
Okay, the wheel cylinder came from Krageons Auto parts. Same as Checker and another name I think. The name on the box is Raymold and the part # is 2037337. Good Luck.
Thanks guys. This turned into one of those nightmare jobs :{
Saturday I got a set at Pep Boys for a 97 GMC 1 ton, 4X4 dually. Got up Sunday figured the weather looked OK, so I went for it. Got on stands, both wheels off, drums free and off, loosened the lines to the cylinders, broke the nuts loose - everything going well and it started to sprinkle. :{ Figured just my luck. So, instead of waiting things out (and have it down pore) I figured I be smart this time - HA! - and put it all back together then call it a day. Of course once I was done, put all the tools away and cleaned up the sun came out until the evening. Great day to do the job. :( Ah well that's the brakes.
So Tuesday after work I get the truck all tore down again and "then" I decided to check the parts out (double DUH!), two boxes same part numbers but two totally different parts :mad: I put truck back together - again. Return the parts and try to get the correct ones - out of stock #@$%! Later on I got them at Autozone, Brakeware P/N 33708, $14. 99 ea. FYI - says on the bag, "Replaces - Wagner #F79768, Raybestos #WC37337 and Bendix #33708". Should have just gone down to NAPA but, most of the time the guys there act like they are the only ones that know anything about auto mechanicals - I don't need attitudes.
Without a hitch tonight (Thursday) they finally went on. I did the gravity bleed on the lines while each cylinder was off to flush old fluid out and then again from the bleeder valve after installing each of the cylinders. Adjusted the shoes and off for a test ride.
I'm not too impressed at this point - the pedal seems low and it really doesn't seem to stop any better, but I'm going to drive it for a day or so then adjust the shoes again and have someone help me to pump bleed the rears. Hope it increases breaking performance. If not I'll remove the RWAL rod and adjust it to suit my needs. That should work ;)
Joe,
I did the larger wheel cyl.
I did not notice an increase in stopping power.
To be honest I didn't expect it to stop better.
I was told the purpose of larger wheel cyl. was to transfer some of the braking duties away from the fronts.
To help balance the system.
Install EGR pads and shoes, if you want better braking power.
Wear your seat belt too cause they will surprise you.
SFB
