ZR... Great way to explain it... . I got that converter before it was patented... so I coudln't talk about it... . No I can and I don't have the words!
Josh
Josh
Is your transmission the one that has 90 idle an 180 w,o,throttle psi. If you could hold the brakes and stand on the throttle and by what rpms is the rear tires spinning. Now I realize that not all brakes hold the same, just a ideal, 1750 or 1900 or later. At wide open how much is the difference between fluid coupling and lockup, 50 or 100 or more rpms. At part throttle how much is the drop in rpm in lockup from fluid coupling.Originally posted by ZR600
I have one of Gorenend's, new triple disk converters. It has a brand new stator, not a milled stator and a trip disk lock up. This converter is very tight on a stock 12 valves. I wanted it this way as I plan on adding power very soon. This is a very nice converter and Dave and his guys are very helpful. I had mine installed and it took around 3 hours and I was on my way back home. The converter starts to get tight around 1250 and is very tight by 1700 RPM. A lifetime warranty to boot. I just wish I would have had them do it the first time I did it. You won't regret this converter as I did my first so called "heavy duty" converter... ... ... ..... Brian
Kurk I would pay good money to get a ride in a truck like that. I am old fashion but that kind of performance is hard to resist. To be honest I have bought some injectors and a 10 fuel plate and maybe even a pump later on. I am going to do some thing to the transmission based on what I learn here. Kurk Thank you JimKOriginally posted by propuller
I have been very aggressive during accelaration on more than one ocassion while towing 12,000 lbs. Two weeks ago we were coming on to the interstate & the traffic was very heavy & nobody was letting me in i had to either pull off the shoulder & wait or i had to go for a small opening that was closing fast. By now im getting a little pi***d off so i stood on it & went for the opening & made it with no problem this was in 3rd gear locked. Keep in mind my truck makes 530 horse with my box off & i am very alert while driving my truck & i listen & feel for anything unusual & i have never noticed any signs of the trans slipping or excessive heat or anything wrong at all. I have also towed for miles & miles at 1500 rpm still no problems. This trans has approx 20 trips down a pulling track & still no problems. Maybe im just lucky but i think that good luck is also made with alot of hard work & the building of a quality product. As far as warranty goes i cant comment on warranty cause i have had no problems. As far as im concerned if you buy a quality product it doesnt need a warranty because you wont need it anyway. I wish you lived closer to me because i would let you drive my truck loaded & unloaded & i think you would make up your mind real quick. That is what i did with my dad & needless to say his 97 12 valve has a DTT trans also & its hooked to a 36 ft Holiday Rambler all the time. You cant go wrong with DTT. Sorry so long.
Kurt
Originally posted by Idaho CTD
I have trailered a friend home twice with a broken DTT transmission… The second time he burnt the first gear clutches without any other damage. Not too bad for a 700hp truck trying to pull a sled with the brakes on. He also has a air locker in the front so all 4 of his tires were spinning. How many auto transmission's from any maker have lived through that?
Nathan
Originally posted by jcarey
unless I am mistaken DTT will not just sell a TC, they insist on addressing the whole system.
tractorface, that's what I read on DTT web site... .
However I saw two well recommended (by TDR members) performance shops that install DTT products offer just the three models of the DTT torque converter (81%, 91%, 93%) for the same price as well as the DTT valve body.
I think DTT needs to update the info on their site...![]()
Originally posted by TxDieselKid
Could it be that DTT(i. e. Bill and Stefan, et. al. ) suggest the whole system, where as some of their installers will do the TC/VB only, as a sort of bandaid. I know Bob Wagner (let me know if I'm wrong please Bob) ran this setup for a L-O-N-G time, and I almost did the same. I think the installers would rather you address the whole system, but know that not everybody will have 400+hp.
Instead of just reading, try asking questions.![]()
Andrew
A few years ago I was told to buy a new factory transmission and just buy a converter and valve body. But things change and improvements are made. HP is sure up. Now I believe there are all kind of improvements made, different apply lever for second gear and bigger spring in overdrive. A better servo, improvements in clutch area and a lot more, close attention is given to ever detail ( accurate measurements of end play in transmission) The goal is to have as little as possible leakage and the factory clearances are wide, Bill insists on close tolerances( his) to get the long life that is know for by DDT.Originally posted by jcarey
I do both, but I think DTT should be aware of what their installers are doing, especially since they emphasize the personal training. Also, I'm talking big name shops on the TDR.
Where are they getting the torque converters and valve bodies from, if not from DTT. Are they pulling out of DTT delievered transmissions?
Originally posted by jimk
Since the topic is, Triple lock vs. single?? If you were able to apply 120 lbs of oil pressure to the make each converter lockup , which will hold more torque? single or triple?
jimk
