Truck gotten LOUDER!! Fix
Battery casing splits
Another New Truck
While piddling with my truck, I found a foam insert on the inside of the front fender that insulates noise from the cab. If you open the hood and look down into the opening(from above) at the top back of the fender, there is a large vertical oval hole(12"X 2")that opens into the door frame. One side on my truck had a thick piece of foam plugged into the hole, while the driver's side piece was stuffed down in the fender compartment( It had either come loose or was never installed correctly). This foam keeps a lot of engine noise from entering the cab. It was a tight fit for my arm to re-install it. I had to get my wife to reach the very bottom.
2001 2500 ETH/DEE Blk/Agate 4x4 QC LWB SLT+ 3. 54 LSD, Every option except Snow Plow and Cab Lights. ARE Z-Series Cap(lined) w/ intregrated electric lock. Bedrug Mopar Blk Aluminum Tube Steps 12000 lb Warn Winch/Transformer Mount- Brush Guard Factory Tow Hooks and all the right gear.
The noise of the cummins is the best part of the truck.
Y2K 2500 reg. cab 4x4 slt 2cg package cummins auto 3. 54 limited slip LNC forest green pearl coat agate interior
But, when she's telling you something. #ad
99' Qcab, 4x4, auto, chrome nerf bars, VA, Boost elbow, DiProcal Pillar mount gauges,
Hey Salvo, thanks for the tip. I checked my fender wells and both of those foam inserts were laying in the bottom. It made a big difference. Thanx also for the tip on using the wife to get to the bottom. Good call. .
regards,,Larry
Y2K 3500, six speed, 3. 54 LSD, driftwood, everything except heated seats, VDO Vision boost & pyro gauges on A pillar
I found the same thing on mine. The drivers side was at the bottom and the passenger side was installed correctly. I would of never noticed this, and it is quieter.
tks
THE ROCK/2001,4X4,3. 54 GEARS,QC,SB,AT,SPORT,CL,CAMPER PACKAGE,TRAILER PACKAGE,WHITE,MOPAR MOLDED SPLASH GUARDS,STEELHORSE NERF BARS,BEDRUG LINER,CAB HIGH CAP.
Thanks Salvo,
I found both of mine stuffed down in the hole. Had to use a long pry bar to reinstall them. (Wife was at work and unavailable)
Great tip!!!
Once again the TDR crew comes through with the fix. #ad
Sparky
1999 2500 SLT, QC, LB, 4x4, White, 4. 10 gears/Limited slip, Trailer/Suspension Package, Auto transmission, Westin SS Nerf Bars, Painless Wiring, Silencer Ring Missing, Mag-Hytec Diff. cover, and more coming (I Hope)!!!
Next addition, Gauges... ...
Pull a 30', Tahoe 5th Wheel (8800 lbs. ) and hardly know it's back there!!
