Engine/Transmission (1998.5 - 2002) Truck runs cooled
Hey guys,
I took a trip between California and Nevada this last weekend on 395. Going through the desert I noticed the temp. gauge at the bottom of normal range and under. This after being on the road for a couple hours and the outside are was about 105 F. I have noticed she don't warm up all the way when going to work but thought maybe I wasn't driving far enough (about 11 miles). Thiniking maybe the thermostst is stuck open. Any ideas? Thanks!
Sounds like the thermostat. I had two fail an the 99 I had before 50,000 miles. One the rubber part came loose and restricted the flow and it woul run hot under load, the other one the cage failed. It has a rubber ring around the top which serves as the gasket, you should be able to remove it and reinstall without leaks if it checks out ok. bg
