ok..... my walbro hasn't completely solved my problem as I has stated in my earlier post. I still have a problem parking nose up on hills. Something else I tried. I ran a fuel line from the walbro back to the fuel tank so I could see if there were any bubbles coming out. There is a very small stream of pinhead size or smaller bubbles that comes and goes. I can't believe that is causing the problems though.
Should I run a flexible fuel line from the filter right to the IP just in case there is an air leak in that hard line? When the truck starts it runs absolutely fine, although sometimes when I pull into a toll plaza it stalls out if I don't keep the idle up.
already done: lift pump and solenoid
