I am looking to upgrade my turbo, (Phatshaft) and with the turbo upgrade comes the need for a new exhaust brake. I will be adding a SB clutch next month.
The truck is used for towing my 5th wheel and occasional long drives. I had 3 injectors go bad, so when it was cheaper to add the 300 hp RV injectors than stock replacements, I went with the 300 hp. I noticed the egt's come up quicker. I am looking to cool things down, not make a bunch more power.
Is the Phatshaft 62/12 or 62/14 going to work or do I go Super Phatshaft? I want to keep the power in the low to mid range.
The 2nd part is finding an exhaust brake that will work with the new turbo. I have the Jacobs now, but it won't work on a bigger turbo. The only option I can really see is PacBrake's PRXB. They have a direct mount (C44064) that looks like the flapper was moved from the elbow to the downpipe. http://www.pacbrake.com/PDF/L5822. PDF.
For anyone that has upgraded their turbo: does the downpipe look like it's for an HX40 mount? The tech guy said it can be mounted with a marmon flange.
Or, has anyone installed an inline PRXB in the exhaust pipe?
