Engine/Transmission (1998.5 - 2002) turbo questions
Engine/Transmission (1998.5 - 2002) Better Turbo??
2nd Gen Non-Engine/Transmission bilstein 5150
I want to go with the BD twins but don't have enough money yet. But I need more air now, so I am going to buy a single. I am going to step up to mach 6's when I get the larger turbo. And eventually add a smarty. Right now with my Hx 35/14 cm housing on level 3 sub level 4 on the edge I can spin the tires in first and into second gear. I also see about 35 to 40 psi of boost. I want to be able to spool the new turbo like like the Hx35 spools. Is this possible? I like the power right off the line.
The best turbo for a setup like you are planning is a 62/12 htb2. It spools like the hx35, but runs way cooler egt's. The 62/12 would be a great turbo for a top turbo in a twin setup. I ran one for 2 months & loved it for towing & fun. The 62 super is a good choice too & egt's would run even cooler than the 62. I like the super turbos, but they do come in about 150 rpm later than a htb2. The super turbo does build boost faster from initial spoolup to peak boost though, but you said that you want it to spoolup like a hx35.
With my Smarty on #9 and my TST on #5, I can push the pyro off the charts (max on gauge = 1600F). With this combo, I peg about 37lb boost. I know it's way outside the map of the HY35, so want to go to a 62/12.
What's the gut feel on EGT reduction -- all things equal -- with HTB2?
I hate having to get out of it on the highway to keep things intact internally.
Thanks
Tim
Htb2 62/14
since I have put the htbs 62/14 on the truck with TST on 5 and smarty sw-9 I will hit about 1200 deg, at 40psi I have not yet hit 1400 deg, at 65 to 70 mph I run between 650-700 deg driving. with no smarty and just TST on level 8 or 9 I dont have much heavy smoke. the htbs does great with clearing up the smoke. keep in mind the smarty pending setting will really work your running gear. I had a bad rear u-joint and didnt know and it destroyed my rear yoke from hitting it to hard. I know now with the smarty on I really have to ease the pedal, the power is there, and its a little less smoke. I went through (www.sourceautomotive.biz) for all of my bombs they helped me. hope this helps good luck.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 CON-OFE TST PM3+SMARTY 100HP/JAMMERS AFE/2 4"SILVERLINE ISPRO PYRO,BOOST,FUEL GAUGES,
TURN-OVER BALL, RIDE RITE AIR BAGS. FASS 95/FLOW PUMP, VULCAN 3/8 FUEL LINE AND FITTINGS, FUEL PRESSURE GAUGE, DSS 03 TRAC-BAR DSS BOX SUPPORT 17'' KMC BLACK HOSS, 305/70/17 PRO-COMP X-AT'S COUPLE OF STUPID STICKERS AND DE-BADGED FOR FUEL MILEAGE. :-laf
I know that industrail injection made the SPS 64 for second gen trucks with your set up in mind. Give Shane a call 1 800 955 0476
A HTT QD 64 or Pro Street 66 would absolutely love some Mach 6's. I'm currently running a Pro Street with Mach 7. 5's with no problems with EGT at all and I have surely tried many. This single had the same ET on just motor than the twins did - launch wasn't nearly as smooth - but it really makes the power. 64lbs of boost with no trouble and the price is right too.
i wish i could keep my 6's cool with my sled puller 66... ... 1600 in about 4-5 seconds.
i guess the NOS helps a lot on keeping things cool
I can get the gauge on up there but for regular driving it's not that bad. I couldn't ever pull a load at all but that's definitely not what I'm in for. :-laf It's pretty fun driving a single again. There is a world of difference between twins and singles - amazing difference.
The 64 or 66 aren't gonna spool anywhere near a hx35 & right off the line is not in these turbos bloodline. This is why I said super 62 or htb2 & if twins are in the future..... this turbo would be best.
I can get the gauge on up there but for regular driving it's not that bad. I couldn't ever pull a load at all but that's definitely not what I'm in for. It's pretty fun driving a single again. There is a world of difference between twins and singles - amazing difference.
Why did you go back to the single?
So basicially your pretty much into second gear before the turbo kicks in. I do alot of stop and go driving and I don't like to be the last one off the line, if you know what I mean :D .
RConner how do you like the F1. 6's? Let me know if you plan on selling them.
I love them the truck should have come with them. Yes I will sell them when I get larger sticks. The reason I would go with larger sticks is because a larger turbo will spool better and faster, Is this correct??
So what combo do you need to get 500+ hp and spool like a hx35 with a single?
So what combo do you need to get 500+ hp and spool like a hx35 with a single?[/QUOTE]
The only turbos that spool as fast as the hx35 is the htb2 62/12. The super 62 is a little slower initial spool, but builds boost faster after it lights. The 500+ range is gonna be a super 62. The egt's would still get up there @ wot though pushing 500+, but would still be manageable via go pedal pressure. :D
