bcbender
Ok, I was getting ready to change my oil and put in my fast coolers when... I noticed oil dripping from the compressor housing of my turbo. I cleaned and ran it and it wasn't leaking from the return line, then I pulled the intake tube and the compressor wheel is very dirty? common? Also I can push the turbine shaft (w finger) side to side and it looks like it moves ~ 1mm not sure, I woudl have to get a dial indicator. The intercooler rubber hose is coated and drenched (outside) with what looks like oil, I havent pulled it off yet. Is it toast? How much should the shaft move, visually w/out a dial ind? I called dodge and I think my warranty will cover. The EB couldn't cause a failure like this can it??
Just looking for some knowledge, this is my first CTD.
