U-joint replacement with alum. shaft
47RE Service
Time for injectors
I've replaced lots of UJ's onother stuff but never on an all aluminum shaft.
Are there special considerations like bracing the ears or do you just push the joints in as usual?
FWIW, they're AAM 1485 type greaseable Spicers.
Thanks,
Scott
Use non greasable ones, they last longer.
But that's just my 2 Ct.
For some reason, they don't in this particular application.
The joints don't wear out but they start squeaking like a violin with very few miles (10~20K). I've given up on them and going to greaseable so I can at least be sure they don't go dry.
Some argue that the reason non-greaseable joints last longer is because the ones with zerks don't get greased. I do all my own maint. so I know they'll get the juice.
