UPDATE: Anyone Have Experience With Cooper STT Pro's?
3 Generations of Cummins drivers
This is an update to my previous thread asking for advice/experience with Cooper tires (https://www.turbodieselregister.com/threads/anyone-have-experience-with-cooper-stt-pros.269797/). I like to read updates/resolutions so I thought I would post one, especially for everyone who was kind enough to post on my original thread. I decided to go with the AT3 XLT's like most you you suggested in my last thread. Even though I had originally wanted to go with a more aggressive tread, everything that I read about these tires told me that, unless I was going to be doing some off-roading in extreme conditions or really deep snow, these were the ones I needed. The 60K mile tread life warranty helped too. So I called my tire shop (ironically they are the local Goodyear retailer) and ordered a set. I went with 315/70R17's. I wanted the extra height and I have a 2" leveling kit, so I didn't think it would be a problem.
Last Wednesday, I went and had them installed and I asked the tire shop to use the Thuren Fabrication alignment specs, which they did. I also spec'ed 50 psi for the front tires and 40 psi for the rear tires. I very rarely ever tow anything and when I do it's not something of substantial weight. I do haul a good bit, but I'd say that about 90%+ of what I haul is 1000 - 1500 lbs or less. Again, after doing a lot web crawling and reading, I didn't feel that I needed to be running my tires at max pressure any more just to appease the TPMS. In the week or so leading up to getting my new tires, I experimented with different pressure settings and settled on 50 psi for the front and 40 psi for the rear. It definitely smoothed the ride out (the rear end didn't seem as bouncy as it used to be) and even gave me back a bit of grip on the worn Goodyear Wranglers I had on. I used Alfo OBD and my OBDLink MX+ to reset the TPMS pressure settings. I did have to get my truck's PIN code to do it. I know that there has been much discussion on here and other forums about that. I didn't have an issue getting the PIN from my dealer, though the parts guy made it seem like he was doing me a favor by even giving it to me. Whatevs! I got the spiel that it might only be good for 12 hours or a one time use code, but I found that to not be true. I did my first TPMS adjustment within a few hours and getting the PIN and did another 3 days after that and the same PIN still worked. At this point, I am VERY pleased with these Cooper tires and the setup that I am using. They are everything that you all said they would be. They are quiet, give a very smooth ride, and with the alignment that was done my truck handles like a dream. I can't wait to try them out in various road conditions. The Wranglers that I had were good road tires for most conditions, but they fell pretty flat on even mild of-road conditions. I don't think that I will have that problem with these Coopers. One thing I will say is that the handling doesn't seem squishy at all. I know that this was a complaint from some folks when their AT3's were new, but I feel that running the lower pressures suited to my towing/hauling style helped that a good bit. As for rubbing with 315's, I do notice a very slight rub at full lock, but I'm not sure the tires are hitting the control arms or the front mud flaps (I'm betting on the mud flaps). When backing on terrain with the back end higher than the front end, I do get some rubbing that is definitely mud flaps (had the same issue with my 285 Wranglers too). The front mud flaps are either going to get trimmed or removed altogether.
Lastly, I did experience an issue in all of this, but not with the tires. It was with resetting the tire size in the BCM so that I would get accurate speeds/fuel mileage. The day after I got the tires, I used Alfa ODB to reset the tire size. The size of my tires was not on the pull down menu so I used the option to enter the tire's circumference (in millimeters). After getting the tire's diameter (as mounted on my truck) and doing the necessary math, I arrived at 2663mm for the tire circumference (the factory setting was 2480 according to Alfa OBD). I entered that in and it seemed to accept it. However, when I started my truck the next morning the EVIC lit up like a Christmas Tree. Some of the information I was able to get was something about the tire size being set to an impossible setting, but there was a lot of other stuff as well. I ended up taking it to the dealer. I was pretty much expecting the worst and convinced that I had bricked my BCM. Fortunately, that wasn't the case. They reset the BCM and now it's okay. The reset didn't seem to affect my TPMS settings any (at least it seems that the RF hub wasn't reset due to all of this), but I will double check the TPMS settings in the BCM to be sure. They only charged me an hour's labor (plus the associated fees). They told me that the 315's I have are an unsupported size and that using that tire size screwed up a lot of other BCM functions. That makes sense to me, but it doesn't make sense that there is a size limitation. The tech told me that 285's were the biggest tire size supported by the BCM and that is what he set it to. Then again, this same tech proceeded to try and tell me that the 315's were out of spec for the load my truck could carry (let alone with the pressures I had them set at). In talking with him, (a younger guy), he was confusing the speed rating with load rating. SMH! So I schooled him on that a bit along with with why I had the tire pressures set the way that I did. I'd be very interested in hearing opinions on this tire size limitation. Is this just a 2013 thing, is it a 2500 thing, or is it both? None the less, I can live with the tire size setting for 285's. When I was running 285's I never reset the tire size diameter and it really didn't seem to make a lot difference with speed or mpg's.
Anyway, I apologize for the long post/update, but here are some photos. I wasn't able to get the tires and wheels detailed because of weather and it being at the dealer all weekend, but the tires still look really good on my truck.
-Tim
2013 Ram 2500 Laramie QC LB 4x4, Thuren Fabrication adjustable track bar, sway bar kit, and 2" leveling kit, Bilstein 5100 shocks, Westin Chrome Ultimate Bull Bar, Weatherguard Saddle Box, Line-X Bed Liner, Cooper Discoverer AT3 XLT's LT315/70/R17
P.S. Yes, as you can see from my photos my neighbor, Clark Griswold, has his Christmas lights up already and yes, you can see that his mania has infected my wife as well. SMH! :)
I am very happy with my AT3 XLT's.
Did you reprogram the ABS module too? I haven't done anything with tire size but I understand you have to do both, and in-between the steps your dash will look like a Christmas tree.
Very impressed with your circumference math. It's only 1mm off of what I get using Coopers rev/mile data.
It's likely the mud flap as the 2" leveling kit brings the axle closer to the rear of the wheel well.
Not sure what that tech's issue was with the Load/Speed as the tires you bought have the same Load Index and a higher speed rating (S vs R).
You could probably drop the tire pressure even more if you wanted to. 50 psi is rated to carry the same load as 65 psi on that size tire, thank you 17" tire specs. You have enough air for the FAWR at 45 psi front and the RAWR at 50 psi rear. Empty I'd be running 40/35, unless they felt too soft... but big tires don't need as much air and on those narrow rims they will want lower pressure to wear evenly.
Looks good! Do yourself a favor, don't get rid of the mudflaps. Your new tires have a habit of catching and ejecting stones!
Yeah, I've heard that about these tires. Good to hear confirmation on this though, so I'll be trimming the mud flaps back some.
No, I did not do anything with the ABS. The ABS was reset when I had it at the dealer. As for the Tech's issue with the tires, I'm guessing that this particular Tech didn't have a whole lot of experience with HD trucks. I've run into this before where rookie techs try to transfer 1500 or car values to my 2500 which don't apply. As for pressures, I'm still evaluating at this point and I do know that I could go lower on both the front and rear if I had to, but for now the settings that I have seem to be working pretty good for me. Thanks for the advice though, as I will definitely be keeping that in mind over the next few weeks as I get more experience with these tires. So far I really like them.
I have had two sets of Coopers on my truck and they’ve been great. I have a toy hauler and camp in dispersed locations. Never been stuck and they last well. Had 80k on my last set and have about 30k on this set with plenty of tread left. They’re quiet on the road, and do well in the Colorado winters. Cooper is my go to. Occasionally Big O will have the buy 3 get 1 free on em. I bought my 285/70/17’s for 800 installed.
I have had two sets of Coopers on my truck and they’ve been great. I have a toy hauler and camp in dispersed locations. Never been stuck and they last well. Had 80k on my last set and have about 30k on this set with plenty of tread left. They’re quiet on the road, and do well in the Colorado winters. Cooper is my go to. Occasionally Big O will have the buy 3 get 1 free on em. I bought my 285/70/17’s for 800 installed. View attachment 125613
So far, I have zero complaints about them. Other than dry roads, the only other condition I've had them in to date is wet roads/standing water and they've done very well with both. I do have to admit that it's going to take some getting used to having tires with good grip. The Wrangler Trailrunners that these replaced were pretty worn and the rear end would break traction a good bit, especially if I took a curve even the slightest bit aggressively.
As I mentioned to someone else, I don't see many trucks with Cooper tires in this area of the mid-Atlantic. What I mostly see are Nitto, BFG, and Goodyear. However, this afternoon I was running some errands and came out of a store to see an F250 that had tires that looked familiar and when got around the side of it, they were the Cooper AT3's. That's the only other truck that I have seen around here that has Cooper tires. I'm sure that there are more, but I don't see many of them.
