flattracker said:
Item one it doesn't cost 400. 00 to ship a convertor from TCS 59. 19 to the midwest I have the ticket in front of me.
First- Did you order a TCS converter from DTT when they still had them making them, or directly from TCS?? From what "I" was "told" by a respected unamed person was that TCS doesn't have a warehouse in the USA and that you have to pay customs which is expensive, 400, maybe i dont know the exact number, but customs is expensive.
flattracker said:
Three several claims of faulty build specs made against TCS but no specifics, TCS is a ISO 9000 certified builder that they suddenly started turning out substandard work is highly suspect. Four if DTT knows that the TCS built convertors they sold were built out of spec where in the hell is the recall? Lastly I have no affiliation with any transmission supplier and will probably have to go to Bolivia to purchase parts after posting this.
The now specifics is true as of now, because the problem isn't fixed and done yet, because i cant get back to my closest DTT dealer until April 29 or 30. As as stated before, we are not POSITIVE what or why is actually going wrong. We have a pressure loss in the oil cooler line coming out of the TC, and when this happens the TC slips, and i will say again, we are not positive it is the TC, but we went through the rest of the transmission completely, and have tried different valve bodies. The 48RE valve body currently in my truck does better because it makes more line pressure and the pressure loss isn't as bad, but i can still make it slip. It does it in 2nd gear, 3rd gear, and OD, and by doing it in 2nd it eliminates 3rd gear cluth pack, OD clutch pack, and something else, i dont remember for sure. main line pressure is where it is supposed to be, and the governer solionoid pressure is also where it is supposed to be. All the clutch packs were inspected when it was disasembeled (spelling??) They looked fine. THe pump specs were all fine as well. I am unsure at this point in time of weather or not the three converters where from TCS or the new machine shop, but i will find out and report back. I would assume that the first two were for sure beings the first one got shipped about a week before christmas, and the second one about a month later, but again am not POSITIVE. After the long explanation, what does it all mean?? Well it pretty much means that there isn't much left to be messing up other then the TC or a passage in the case that has a crack in it causing internal pressure loss. Because there aren't that many pressure passages in the case, it would seem that the cause would be weighted more towards the TC, but who really knows. When i find out more info i will be sure to post it!!!
Again im not trying to start a war, but if all three of my TC were from tcs and that is the cause then i think this would be information that many people would want to read before purchasing a TCS converter.
PS- If anyone that knows anything about transmissions has any other informational guesses on whats going on with my transmission, that would also be much appreciated.
