2nd Gen Non-Engine/Transmission wait to start light
Jr I've never reset it and I was saying on another post that if it is ecm not to replace it just relay it of the injector pump I'm not sure about that. If u could post how to reset apps I would appreciate it I'm gonna redo all my grounds change the factory lift pump relay and reset the ecm and clean and inspect the ecm connector this weekend
APPS reset procedure:
1. Set parking brake
2. Disconnect negative battery cables on both batteries
3. Turn ignition key to run(to drain any remaining capacitors)
4. Let truck sit for 30 minutes( this is the recommended minimum)
5. Return ignition to OFF position
6. Reconnect both batteries and secure, not a timed event
7. Turn key to run position(not start) and depress accelerator pedal slowly all the way to the floor
8. Allow pedal to return to top position slowly
9. Turn ignition switch OFF
10.Release parking brake
