Engine/Transmission (1998.5 - 2002) What are the fittings that connect the ......
I am going to put in an aux cooling core for my transmission before the water heat exchanger. I have the '95 hot line with the temperature port in it.
I looked at it last night and am trying to figuer out what the correct fittings are.
At the rear of the water heat exchanger (the end closest to the cab) I think the fitting that is in the water heat exchanger is a AN-8 male, is that right?
At the end of the '95 hot line that is closest to the water heat exchanger I think the fitting on the end of the hot line is a AN-8 female, is that right?
I need to make sure so when I order adapters I am getting the correct parts.
The above is what it looked like to me.
Bob Weis
I realize this is extremely old but I had the same question and can't seem to find it perusing through the forum search. Are the fittings on the heat exchanger (coolant/fluid) -8 AN or different flare?
